Special software? What is special about the software. ...
Because the speed control's processor won't operate correctly below a certain voltage. The special software allows the controller to keep the voltage above the minimum operating voltage of the processor. Without the software the controller will shut off randomly when the voltage dips down below the minimum.
Ahhh very cool, I hate when my controller randomly shuts off!
Wil this version have a LVC for 1s ?. Also can i assume i still need a reciver pack or external bec pack or a novak smart boost for the radio ?.
It will not include a 1s LiPo cut-off, that is something I will be talking to the engineers about.
You assume correctly. Because we've had to disable the onboard BEC for 1s operation, you will need to supply external power to the receiver. That can be done by using a separate power source like a 2s LiPo with an external BEC or a 4/5 cell receiver pack. You can also boost the voltage using a product like the Novak Smart Boost.
Thomas Porfert
Castle Tech Support
It will not include a 1s LiPo cut-off, that is something I will be talking to the engineers about; I'll
Thomas Porfert
Castle Tech Support
Clarification -- "Custom" cutoff voltages (through Castle Link) will be available for 1-cell range, but there will not be a stick programming option other than "Auto-Lipo" or "Disabled".
Patrick del Castillo
President, Principle Engineer
