Finnster
KillaHurtz
Finnster's Avatar
12.11.2009, 12:23 PM
I was looking at that a couple weeks ago. I think it just came out. It looks pretty nice, tho I'm not sure I'd trade away my XL as is for it. IDK, one of both would cool :)
The stock radio box def needs to go on it, but otherwise I like the kit. Some 24mm adapters would be cool as well.
Ideally some wider arms would be nice to bring this to a better scale. I do wonder at what point the truck gets too big to be durable for the 1/8th Sav platform, tho I doubt that truck weighs all that much more.
I too was looking at roll cage options. I haven't found anything too satisfactory. New era has some decent rool hoops, but the are only avail for the F or R half. They won't make a full length one. RC Innovations has one too, but more for the nitro, and as most, have bars on the side that would block the batt trays, and is a little fugly anyway.
I was looking at making one of plastic rods, or possibly alu sheets, like TVPs, tied together with spacers. Looks like the do this on here and add some delrin reinforcements too.
Either way, for $150, its not too bad of a kit. RCM should be work on some Flux gear. All these companies coming out w/ conversions and stretched TVPs, there could def be some things to bring out to compete/compliment. (*cough*, CD/slipdiff kits, 24mm adapters, other 1/5th conversions, etc. *cough*)
Freezebyte
12.11.2009, 12:42 PM
Impressive to say the least, but if I want a 5T, i'll go buy a 5T.
12.11.2009, 01:00 PM
where? not available stateside.....
12.11.2009, 01:08 PM
FLM wide arms?
Finnster
KillaHurtz
Finnster's Avatar
12.11.2009, 01:19 PM
FLM wide arms?
That's what I was thinking. Some guy was trying to get a 2" wider set put together as a group buy.
Plus its not 4x4. HPI made a 4wd 1/5th scale, but they even made if off the savage. Not for US tho :(
12.11.2009, 06:03 PM
I've got the standard flm wide arms on my savvy (.5 inch per side, 1 inch total) with the extended low cog chassis and it is awesome! Big and stable. Of course 2 inches would be even better, but the 1 inchers really made the savvy a whole new truck. They are strong too.
thzero
01.15.2010, 12:29 PM
I ended up getting one... I've been debating about whether to convert my nitro Savage XL into brushless to join my RC8Te; and well going 5th scale with my RC8Te is a bit more than I want to pay for to get custom chassis done so it's on hold til I get better machining skills myself and can do it. So I'm anxious to see what the kit is like.
RC Universe has a post by a guy who put Jammin' X2 arms on his Savage, looks from the pictures like they match up pretty well. Thinking about looking into this myself. Downside is that you are stuck with a 17mm hub unless you get a custom one made (same issue with the RC8Te I have) where as with Savage you can get Pro-lines 23mm hub and with a bit of shimming it works.
FLM wide arms?
