brushlessboy16
brushlessboy16's Avatar
12.22.2009, 12:27 AM
Ah - they do have the spline on them dont they. Yeah, that 23 was supposed to be 24.....
I see no spines on the hubs
Helly
Helly's Avatar
12.22.2009, 02:55 AM
Thanks all for your interest!
To suicideneil: you right, it's a 5T
The rear center driveshaft is huge ! Did you make it yourself ?
You won't use a skid to protect it ?
Yes it's a homemade driveshaft with juste a aluminium tube between classic revo shaft and two screw to hold them...
for the hub, i forget to add this pic: (it's just 23mm hub with around 0.4mm plate to add the extra 1mm!
01.16.2010, 10:25 PM
1st time I have seen this done, but I have thought for a while that it would work fine. Just finding stock that is the correct thickness, looks like brass shim stock you are using?
JThiessen
JThiessen's Avatar
12.22.2009, 10:02 AM
I meant on the traxxas version - not these...
Helly
Helly's Avatar
01.16.2010, 01:18 PM
It seems to work very well!!! lool
Neu 1515 2D with 7s2p A123 batterys... tone of power!!
temp motor: ~120-140°
temp mamba: don't really know but the fan never turn!
Ok we are in winter, but it seems really performant!
I have juste some probleme with the front shock oil... front shock really have hard time... (8kg for the complete beast)
