HomeGrown
HomeGrown's Avatar
12.27.2009, 11:33 PM
my motor is only rated for 2s..(7700KV MM) i dont plan on upgrading or downgrading my motor if these LiPos dont blow..and for the power supply i have a car battery lol.. i'll get the plugin for that charger eventually..
BL Pede, Integy aluminum steering linkages, aluminum shock caps, RPM camber links.
Never Replace Always Upgrade!
12.28.2009, 12:31 AM
That 7700 is a hot motor. I had a hard time keeping the temps down in a stock rustler, the stampede is little heavier, and the bigger tires put a much larger load on the motor.
I'm just warning you, right now the batteries are your weak link. Once you go lipo that 7700 will get HOT and it may die on you. Then if it demagnetizes and you try to drive it the esc can blow quite easily. If you don't have one I would get a temp gun, and check temps often!
I would still go ahead and upgrade to lipo, but I would keep in mind that a motor will probably be your next purchase. There are plenty of motors that will push your stampede on 2s. Then you should be solid and not have to upgrade.
J57ltr
12.28.2009, 12:59 AM
When I first got my mamba max and 7700 I ran Duratrax 4200's and they did ok as long as I was geared 87/15 in my rustler on the street when I went to a 17 tooth I actually popped one of the cells. The hobby shop replaced it under warranty. I got an eagle tree data logger and found out I was pulling 126 amps and pulling the pack down below 5V. For a while I still ran this setup but more closely monitered the temps. I still managed to kill a second pack. After that I got a different motor to tame it down a bit. I still run it from time to time but switched to A123 batteries and just run speed runs with it.
Jeff
HomeGrown
HomeGrown's Avatar
12.28.2009, 01:52 PM
Jeff
i was running DTX 4200s i've blown like 6 cells of them.. never really had temp problems..
on another note i have a buddy that would trade my 7700 for a 5700 mamba.. think i should do so?.. and if i do wouldn't i be losing speed and torque? i love poppin wheelies on demand.. i only bash but race cars up my street often.. i like to see their when my RC passes them.. i guess i'll opt for the 40c packs.. does it make a difference with a hardcase? because i bash the hell outta my truck and hardcase just seems logical.. whats the pros and cons of a hardcased lipo?
also if i swap motors i could go bigger then just 2s.. i think that 5700 is rated for 5s or 6s lipo..
12.28.2009, 02:54 PM
the 7700 refers to how many rpm's per volt the motor turns. On 2s the motor spins at 56980 rpm (7700kvx7.4v=56980rpm)
The 5700 on 5s would be 105450rpm (5700kvx18.5v=105450rpm) that's way too much! You don't want to run the castle motors past 60,000rpm. You could go 3s on the 5700.
With the 5700 you would GAIN torque and lose speed. A lower kv motor has more torque than a similar higher kv motor.
The 5700 would still do what you want on 2s (wheelies at will) and run much cooler than the 7700.
I would sell off the 7700 and get a bigger motor(not castle).
J57ltr
12.29.2009, 12:53 AM
I bet it was one of the cells opposite the battery leads. I got the batteries real hot one time. We had a pile of dirt where a house was being built next door and a friend and I were climbing to the top. I was running the 7700 and it was geared pretty low (87/12) and I was also using my eagle tree with a temp sensor on the battery, ESC and motor. The motor and ESC was pretty warm around 130 and the batteries stopped at 200 at about 3 minutes into the 6 minute run. I have no idea how it really got because I had accidently set the upper limit to 200. That was measured under the wrap.
I used a Feigao motor (4436Kv) and they are just about identical to the castle cm36 motors. Like the guys said 5-6S would be death, although you can usually get away with it a time or 2. I have run the 7700 on 3S2P A123 and it cranks out some serious power. It's real hard to keep it from flipping a rustler on it's lid and it's kinda like going over a cliff, you still hit those brakes.
I also have a Nemesis blue 6 turn motor (5915 Kv?) and it does very well also. I would say it's probably right along with the CM36 and Feigao motors. I have run it on up to 4S2P A123 and it flies. I have run all these motors on Nimh and wouldn't recomend the 7700 with them. I run mostly on the street which is a little easier on batteries, so if you run offroad a lot you should probably try to get that 5700 or lower when you can.
Jeff
12.29.2009, 01:39 AM
Jeff
nemesis blue is just a feigao that chris fine from fine designs put a sticker on. isn't capitalism spiffy?
J57ltr
12.29.2009, 02:29 AM
It's not hard to tell just by the way they are constructed. Rebranding isn't so bad as long as you know what's out there. I remember in the 90's Autotek, Hifonics, Rodek, Earthquake, and at least 3 other "manufacturers" had amplifiers that were all made/designed by a single company. They were all good amps they wern't Nakamichi or A/D/S but they were powerful and pretty good quality.
You have to think that when you are coming over from brushed even the entry level motors are fast. A Neu is nice but a Nemesis is.... ah hell I got nothing...
Jeff
