winkje
01.14.2010, 07:47 PM
Patrick,
Thanks for your reply!
It takes guts to answer the way you did and I do appreciate it. Thanks for that! I tried to send you a PB but due to a full mailbox on your side I didn't succeed....
I do appologize for using some firm words and expressions; I do hope you understand where these came from.
Regards, winkje
@SuicideNeil; I trust you to understand I will not respond to your reply....
JThiessen
JThiessen's Avatar
01.14.2010, 08:00 PM
Winkje's issue is not an isolated one, and he will have problems in the future on some other HV brushless system. It took repeated attempts to get my bother in laws to bind with the MMM - I think I sat there doing the programming over and over again for about a half hour until it just finally "took" - I didn't change what I was doing with it the entire time. He had the same issue trying to use the Futaba with his Novak system. I've been around this stuff long enough to understand that sometimes certain things just dont mix well. My choice would have been to ditch the Futaba, not the MMM.
