rchippie
rchippie's Avatar
01.22.2010, 08:37 PM
He doesn't (I was on the phone with him yesterday), so he's gonna get that board and also a cable specifically for Hyperion. If the board's connector cable won't work, he'll just splice in the Hyperion connector.
I called protek today which is owned by amain hobbies . The tech said there stuff is patterened after hyperion . So it should fit . If not i'll have the hyperion plug as brian mentioned . I also asked about this board doing both xh & eh plug ends . He said it will do both . so im assuming maybe they used a slightly wider plug housing with the correct pin spacing . But im not sure . If it does not work i'll just send it back . Brian what's your opinion on it doing two different plugs ?.
REAL MEN RUN BRUSHLESS
