Stumpjumper
05.03.2010, 11:34 AM
Almost done
Some srews are replaced by M4
even the balance point is on the right place I think...
All straight, many black parts
Temp-Display on receiver and in the middel the LiFeDiMatic
The ECS whit temperature sensor. Under it the Ultimate-BEC
Stumpjumper
05.03.2010, 11:36 AM
weighing:
either
or
5800g - RTR Chassis incl. small Cage
1112g - the lightest Wheels I have
thatīs 6912g
Whit Body and big Cage 7,7kg. But even for show.
I hope you like it...
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
05.03.2010, 12:43 PM
.... Gosh... it's such a beautiful build... That all black hummer body sure adds some personality to the truck... it seems pointless to compliment you on the design and build because you
already know it looks so damn good... but, I must... great work man... the thought process and engineering that went into the truck is just outstanding... I am sure if you got these parts in the
aftermarket seen, they'll do very well... glad you could share it with us here.
TexasSP
Something, anything, nothing
TexasSP's Avatar
04.29.2010, 11:19 PM
I believe the "concrete" in his picture is actually paving stones. The uniform shape, layout, and unevenness leads me to believe this.
Of course I was to busy drooling over the truck to notice concrete and had to actually go back and look to figure out what was going on with that comment.
Stumpjumper, I really think you may get bored with this truck and should go on and ship it to my house. The address is.............
www.cubicle101.com
Overdriven
Destroyer of Tires
Overdriven's Avatar
05.03.2010, 12:49 PM
You hope we like it???? How could we not!!! Definitely one of the most epic builds ever. Very well done.
el tomaso
05.03.2010, 01:18 PM
The greatest build ever!
TG
Manne
05.03.2010, 05:30 PM
Indeed very very good!
JAILBIRD
05.03.2010, 05:41 PM
WOW!! Very nice work.
I have a CNC Router and have been thinking about making some custom parts out of carbon fiber. What kind of speeds and feeds (tool RPM - cm/minute) did you use to get such clean cuts? This is the machine I have:
http://www.data-technology.com/profile.html
Thanks!
-JB
rc4x4nut
05.04.2010, 07:57 AM
Damn that is a beautiful truck. How rigid is that chassis with the cage? In some pics it doesnt look like it has any bracing lick the truggy chassis.
Also, a stretch, but have you thought about doing a limited production?
Stumpjumper
05.04.2010, 10:17 AM
@ all - thanks
@ rc4x4nut - Yes I think about a conversion kit but not full. Only for the normal Nitro-LSTīs. There are so many things I arranged in the gear box. The motor mount is so complex. I donīt want to build it again.
@ JAILBIRD - I use VHM tolls (VHM = Full Harded Metall). We used it normaly to cut hardened steel (about 58-62 HRC).
If you toke normal tool stell cutter itīs blunt very fast. Speeds and feeds - very slow! Itīs a matter of feeling. Also lining. Carbon is so disgusting.
And donīt forgett to exhaust! We have a very big exhaust system. Itīs the big pipe you can see on the pics...
and the smaller one I normaly use for this stuff
olli
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
05.04.2010, 01:09 PM
You are an inspiration. This build is extraordinary. Makes my builds look like child's play. I don't use a CNC, I don't have the knowledge to use them (yet) or the CNC machining either. I do most of the stuff by hand but for cutting CF, diamond disks make a very clean cut. For making holes and counter sinking, Carbide or Tungsten carbide bits and end mills cut through CF like butter and also make very clean cuts. I can only use high speeds because I make the cuts with a cheap router on a small router table and it only has one speed, fast
Thank you for sharing this build, it is truly wonderful.
No brain, no headaches.
05.04.2010, 02:11 PM
Well, thats another truck I have to inseminate I guess...
Awesome setup you have there, turned out some truelly stunning work with it.
Stumpjumper
05.10.2010, 10:38 AM
After 3 runīs....
Itīs still the first slipper. It alived the nitro stuff and the last conversion whit the Big Maxximum at 18 NiMh Cells. But now I need a new one.
nitrostarter
nitrostarter's Avatar
05.10.2010, 10:53 AM
Are you going to manufacture your own?
N. Rustler conversion
Stumpjumper
05.12.2010, 02:09 PM
of course!
And here is it:
olli
