SpeedAssault
SpeedAssault's Avatar
02.17.2010, 03:22 PM
My experience is that AM is horrible... Maybe it's just my neighborhood, but AM always glitched badly even before I went to BL. FM is a big improvement, but still glitches sometimes. FM is more succeptible to interference from metal-on-metal noise. 2.4 pretty much eliminates glitching due to radio interference.
Edit) the only thing that I have changed is I made a 1/4" delrin battery tray. Dont know if it's related but it's weird that it ran ok for about 8 minutes and then I turned it off. I went back out and it was twitchy like crazy after a minute.
Thank u, wow metal on metal, well if fm is better than am for glitching then that is the big problem.
I have MOD 1 steel Spur gear with metal pinion and the steel dog bone driveshafts as well.
Should I buy a novak xxl Fm rx for my Ko propo FM radio or is that going to be a waste as well ?
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
02.17.2010, 04:04 PM
To elaborate a bit, AM can be thrown off by pretty much any EMF of sufficient strength. So pretty much anything electronic () can make it glitch unless the offending device is properly shielded. FM isn't as succeptible to general EMF, but metal-to-metal friction can create high frequency EMF that interferes with the FM signal. I had that happen on my Rustler. I was using a Futaba 3PM-FM. It would be ok at low speed/close range or low speed/long range, but at high speed it would glitch if it was too far away... So I'd be accelerating away and all of a sudden the car would just veer off the road into a bush; which meant that whatever interference it was recieving from the fast-moving drivetrain became stronger than the Tx signal at long range. When I got my Spektrum radio the problem disappeared.
