02.22.2010, 07:50 PM
The way I see it is this:
Having the motor and diff / slipper unit mounted up front wont make the blindest bit of difference- all you are doing is shifting a few hundred grams of weight ( at most ) a few inches forwards; when you put 1.5-3 HP through the truck its still gonna pull wheelies and do standing backflips all the same...
As for it not being for racing- I think the chassis will be perfectly raceable, its no weaker or worse designed than a GorillaMaxx chassis, infact its better as its narrower and has a lower center of gravity due to the transmission design; so long as 6063 or better aluminium is used Im sure it'll be a race winner- just needs a good driver
plettenbergs
plettenbergs's Avatar
02.22.2010, 09:05 PM
well put...your check is in the mil!!
Rivermaxx
02.22.2010, 09:26 PM
All I was doing was stating the obviouse and my opinion. For $400 I would expect it to perform as should you guys. I disagree with you neil as far as the placement of the center diff and motor. Like I said before it is a nice looking setup and if it was designed a little different I would be all over it. Its not like it couldnt of been done when he was reverse engineering it. Most likely it would of cost nothing more. I would put my $179 chassi g4maxx up against the $400 maxxler chassis any day.
plettenbergs
02.22.2010, 09:39 PM
that is a good idea River...i will look into that for the second run...it could be moved forward a little as long as it was not be too close to the steering rack!!...i am trying to keep costs down and get the thing completed,"MY PAPPY SAID"if it aint broke dont fix it,IF IT BRAKES,get some duck tape"
Not equal
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Not equal - 02.23.2010, 03:07 AM
For $179 you received a chassis and top plate, correct? This project kit is a little bit more involved than that. Maybe you have not been following this from the very begining Beau, but he is not only supplying the chassis, but also the center diff mount, slipper/clutch, and one or two other items with this kit, which you had to acquire on your own. Plus the fact that this unit provides better options for battery placement. In fact this setup leaves things open to the imagination for individual setup designs. So comparing the G4Maxx really is not a fair way to make your case as far as value is concerned. Sure it is still a Maxx truck no matter how you slice it, and $400 may even be a little bit steap compared to some, but we have no idea what this is costing Matt to reproduce. We all know that CNC work is not cheap by any means. Plus as far as I am concerned he deserves a little something for making a few improvements to the original design, which had some really weak areas on the chassis. UE Lightning chassis's are selling for $800 and even though we may not agree with that people are still paying out that much, because that is what they want. People have been waiting for 2 years, and want this Maxxler chassis whether you believe in it or not.
SUPERMAXX YOUR LIFE.
02.22.2010, 11:31 PM
Battery placement is more critical than anything else. If you put the batteries in the back and the motor up front you would have a wheely monster...
George16
Supermaxx
George16's Avatar
02.23.2010, 03:55 AM
Jerry, your box is full.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
got it
JERRY2KONE
JERRY2KONE's Avatar
got it - 02.23.2010, 04:14 AM
There is room now.
Kcaz25
Kcaz25's Avatar
02.23.2010, 02:41 PM
Yeah I agree with Jerry, Neil, and James. The people interested in this know what they are getting into. They don't need you to educate them River. Tons of popular trucks have similar placements. This is one of the best if not the best E-Maxx chassis available for various reasons. I would request one if I didn't just build a BL Mutant.
moogenite
Let non survive!
moogenite's Avatar
02.24.2010, 01:28 PM
Everything without center diff is wheely king at these power levels.
Doesn't matter how its balanced.
Forgot to say, its AWESOME
emaxxthemonster
jt racer
02.24.2010, 10:37 PM
i may be interested in one. i dont know yet
02.24.2010, 10:49 PM
we're going to need more of a comittment than that. Please leave a credit card number (Visa) with expiration date and three digit security code
plettenbergs
02.25.2010, 08:06 AM
dont forget SS# and mothers maided name!
killajb
killajb's Avatar
02.25.2010, 11:33 PM
+1 on Linc's observation regarding battery placement. I think shifting weight as well as adjusting the slipper clutch will help to balance out the chassis weight transfer front-rear during acceleration.
Suspension tuning as well will help things out. I think some comments were a bit harsh regarding this truck. Anyone who was willing to drop the necessary coin on it should know what they're getting.
