ANGRY-ALIEN
ANGRY-ALIEN's Avatar
02.19.2010, 11:24 PM
Well... I'm not sure the fan is problem... it does kick in at 139° internal during 'Charge mode'... and it does sound healthy... I also just remember it won't go over 5 amps too for
'Charge mode' even if I set it for 6.... Could it be the Fets? or could it be something bigger?
sikeston34m
sikeston34m's Avatar
02.19.2010, 11:55 PM
I'm not talking about the power supply fan. I'm talking about the fan inside the charge unit itself.
The charge unit limits it's charge amperage to the capability of the power supply. They are matched. Think of it in watts of output.
The larger the voltage of the pack, the lesser the amps that it will charge at.
I'm sure it will charge at 10 amps if you're only charging one pack, but put them both on in series, and it's going to limit you.
ANGRY-ALIEN
02.20.2010, 01:44 AM
Yeah... I was referring to the charger fan and not the power supply's... the MRC power supply packed in for a few months now.... I am using a HP DPS-600PB B 575W POWER SUPPLY
I understand the concept of current draw when Charging, but does that principle still apply to discharging as well?
sikeston34m
02.20.2010, 09:15 AM
Yes, it does.
That looks like a pretty hefty Power Supply. cool
ANGRY-ALIEN
02.21.2010, 12:08 AM
I believe it does, though the manual/ spec sheet should answer that question in more detail.
The manual really only speaks to heat generated from high amp discharges... nothing about current draw from the power supply.
Yes, it does.
Yeah... but I really can't get the full potential from them... I'm current running them on 110V source and 220... so the watt output is a little lower than advertised...
even hooking up 2 of them in series or parallel (which not a safe thing to do), still won't provide enough power to satisfy the needs of the charger.
