gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
02.26.2010, 08:06 PM
Taking out the spacers on my belly pan seemed like an easy 45 min task. Not so much. One of the nuts that is inside the frame came loose and was just spinning with the bolt. Thanks previous owner
Tried a sawzall...ate FOUR of my blades and only cut half way through. wtf? Must be a grade 8 bolt!
Busted out the grinder and cutoff wheel...got that sucker off there. Also got the insert out so I can put a new nut in there if I can find the part and order one.
Where I left off
Goodies
:D
