riverat1540
riverat1540's Avatar
03.03.2010, 04:53 PM
It will draw power and drain the batteries even if the switch is off, The only reason i can see u doing this is because you are worried the connecters will come apart during the race leaving u dead on the track, i suggest deans plugs and if the problem is them separating, use a small zip tie and cinch the plugs so they stay together, u can run the tie right between the positive and neg wires and they will not separate unless u cut the tie
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
