coolhandcountry
coolhandcountry's Avatar
02.11.2006, 10:12 PM
Yep it does. I took and soldered one in and one outside the 3.5 plugs I used. I don't know about the 5.5 plugs.
Peace!
Country
Help support the
Rc-Monster
Buy here
02.11.2006, 11:07 PM
OK, thanks. That's kinda what I figured. If one wire fits in a 3.5mm connector, maybe two can fit in a 5.5mm connector. I guess if it doesn't, I can always do what you did. Does it look OK with one of the wires soldered to the outside of the connector? Maybe I'll solder the two wires to a short (1") piece of 8GA or 10GA wire and then that to the connector. A piece of car amplifier wiring should do the trick...
