Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
The Dude
No Way....
The Dude's Avatar
03.07.2010, 02:22 PM
Hi
Nice conversion !!
it's funny cause I started to convert my MGT... starting of thinking about it !!
here's a pic of my differential support
I gonna use a MMM with a CC-Neu 1518/1Y motor
The center diff is a X-Ray from a XB808
and here my MGT (a lot of upgrading...)
follow your post
(sorry for my English...I 'm French )
Krawlin
Got brushless?
Krawlin's Avatar
03.07.2010, 06:54 PM
Wow, that looks great! What brand of shock towers are those and where can I get them? Or did you make those yourself? Also, your design was the "final push" for me to update my design a bit, thanks for posting that! I'm looking forward to seeing how yours turns out.
Since my motor plate bolts to a center diff mount, doesn't look as clean as it could, and probably not as strong as it could be either. So I decided to update my design, and used "The Dude"'s motor mount as inspiration for an update.....
Since 3/16'' is a bit on the thin side to drill for M3, I am going to slice a section of the bottom off the motor plate. Then, I am going to cut a piece of 1/4'' plate to the proper height, cross drill it with the same hole spacing as the current diff mount and thread it for M3, then weld it to the motor plate. Next, I will cut out a couple of tabs from 1/4'' plate, drill completely through them, and weld them to the motor plate at chassis level, then drill through the chassis to use a bolt at each tab. Finally, I will weld a thinner plate over the current hole for the outdrive in the motor plate, which happens to be the perfect diameter for the center diff bearing, and put a hole in the welded on plate just big enough for the outdrive to fit through but wont allow the bearing to go through, basically turning this into a center diff mount and motor mount with just 2 separate pieces. Simple, strong, effective, and should look cleaner than the current setup once it's done. I should have some progress on this by the end of the week or this coming weekend, so stay tuned for more updates, and as usual, comments questions, and more importantly, suggestions, are always welcome.
Monster GT Conversion
The Dude
No Way....
The Dude's Avatar
03.08.2010, 03:35 AM
It's the NewEra tower, not really cheap, but very strong !!
thanks for the comment on my support, it's my first design...w/ google sketchup.... a friend gonna make it on AutoCAD, and after a another friend make it on CNC... it's AL of 6 mm , using M4 screw under the chassis, and I made a ...look a this (I don't know how to explain this in English... )
in blue it's a lexan sheet of 1 mm for protect the central diff..
I stay tuned ... and if you've got another vid'
Krawlin
Got brushless?
Krawlin's Avatar
03.09.2010, 01:40 AM
Are those New Era towers a 2 piece design where the bottom "feet" bolt to the top? Seems like it from the pictures on their website but I can't really tell.
Anyway, looks great! Keep us updated on progress on your setup.
Just bought two M3 taps (bought two in case one of them broke) for my motor mount design change.... $5 each from SnapOn, but they are made in the USA and SnapOn is pretty good quality, so I guess it's not too bad of a price, but I see why full tap and die sets cost a small fortune. I also bought a couple drill bits of the proper size (2.5mm and 0.0995'', basically the same size but one is a backup in case one of them breaks). Anyway, probably going to cut out the pieces I need for the design change/update tomorrow, so stay tuned!
The Dude
No Way....
The Dude's Avatar
03.09.2010, 04:08 AM
yes it's a 2 pieces design
Krawlin
Got brushless?
Krawlin's Avatar
03.09.2010, 01:01 PM
Ever have any problems with the screws that hold the 2 pieces together bending/snapping? Call me paranoid but I don't like the 2 piece design really unless it keyed together or something, not just bolt together.
I just broke another rear shock tower, 3rd one in 3 weeks. Not from landing upside down or anything this time either, did a really high jump, landing perfectly flat, but the shock tower couldn't take the stress I guess, must have been weak points in the tower though because it broke in 2 different places, not evenly across. I may try GH Racing towers, I've had good luck with their parts on my Maxx and they use a 1 piece design.
This truck needs some work though, the bugs are starting to come out. The steering setup is decent at best, I need a cam type servo saver setup for it. AE and NewEra both have a setup like that. Also need aluminum shock towers, and on the front arm mounts, I need to put in a longer screw with a nut behind it to keep from stripping out the chassis's threads (which I did to the right front upper arm mount already years ago when it was still nitro). I also need a better servo, this Hitec 645 just isn't cutting it, the truck turns like it's a semi. But other than that, so far so good.
