scarletboa
scarletboa's Avatar
03.09.2010, 01:53 AM
it is a problem with the connectors. i had the same problem with my savage flux. the deans connectors get just slighty warped when soldering and you don't notice it until you put a warped plug with another warped plug.
i have remedied this problem by plugging the male and female plugs together when soldering.
notnodak
03.09.2010, 02:14 AM
I'll check but I'm using a TRX. I might try to put a new plug on it.
scarletboa
scarletboa's Avatar
03.09.2010, 02:33 AM
trx and deans are very similar.
how exactly is your esc not detecting the battery? have you tried jiggling the plugs while the esc on/off switch is on? when i did this with my warped plugs, it would turn on and off as the connection was broken and re-established.
it could also be a bad solder joint inside the battery itself. i had to re-solder one of my zippy packs.....twice. once for the main (-) lead and once for one of the balance wires. the pack would work on the charger, but not in my truck. once i opened up the pack, i realized the problem.
notnodak
03.09.2010, 11:13 AM
I'm betting on the power plug because I get correct voltage at it but I'll admit it's making me scratch my head. I'll find out in a little bit.
