Houston we have a problem
bigboi146
Multi Tasking
bigboi146's Avatar
Houston we have a problem - 03.13.2010, 08:50 PM
So I have a castle neu 2200 with a pinion stuck on it. The set screw is completely stripped and I have no way of getting it off. I want to run my truck but not with this bumb a$$ 9xl what should I do? ( I have no demmel)
skellyo
skellyo's Avatar
03.13.2010, 08:53 PM
No drill to drill out the set screw?
JoFreak
JoFreak's Avatar
03.13.2010, 08:54 PM
Do you have a handsaw?
You could try to get a slot into the set screw and get it out with a flat head screwdriver.
Or you could try a slightly bigger torx and drive it into the striped set screw with a hammer to unscrew it.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
03.13.2010, 09:09 PM
I suggest you buy a Dremel tool.
03.13.2010, 09:24 PM
+1 for that...it is a must have
BP-Revo
BMW M Power!
BP-Revo's Avatar
03.13.2010, 09:43 PM
Usually you can pry the pinion off the shaft (slide it off the front).
scarletboa
scarletboa's Avatar
03.13.2010, 10:03 PM
i had to cut my pinion gear off the shaft with a dremel. it was the only pinion gear i had besides my (now broken) rcm gear that i had just gotten that fit and wasn't worn out.
03.13.2010, 11:20 PM
Google > 'pinion puller' =
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
03.13.2010, 11:44 PM
http://tinyurl.com/yl2cpac
bigboi146
Multi Tasking
bigboi146's Avatar
03.14.2010, 01:14 AM
So i think I'm going to go with the pinion puller!! Thanks guys.
shaunjohnson
i pwn nitro
03.14.2010, 04:14 AM
there is one last option that may have not been suggested, hope i'm not too late.
if you have a drill press (vertical drill, whatever) and a good one, not just a toy dremel one or a hand drill stuck in a holder one, a manly bench mounted one.
you can actually fabricate a pair of struts that sit across under the pinion and then using the drill press with an up-side-down drill in it, you can push the motor/shaft away from the pinion.
this is how i do it but i have access a lot of large machinery, a nice new lathe is comming soon, 2.5 tonns of awsomeness (spins up to 2ft diameter jobs )
What's_nitro?
03.14.2010, 03:11 PM
Making some alloy wheels?
Modding_out
disturb'in the peace......
Modding_out's Avatar
03.14.2010, 04:21 PM
OMG!!!! How did you do that???
shaunjohnson
i pwn nitro
03.14.2010, 04:49 PM
google search "lmgtfu" and that will take you to the site
i'll make whatever i want!!
i jus dunno what, alloys on my nissan manette just wont look right without lowering it...and you cant lower front leaf springs i dont think
2ft wheels for the revo
heavier flywheel for my next car.
gonna be sick!!
03.14.2010, 04:57 PM
Sorry, its a secret, used by evil people to pown noobs...
