scarletboa
scarletboa's Avatar
03.17.2010, 12:49 AM
A Kyosho plastic spur will fit. I don't understand how you manage to shred pinions with steel spur. I had been running my ST RR with a lightened 46T Kyosho steel spur with an RCM 15T pinion since Feb last year and the teeth still looks new. Are you sure the mesh is okay? You have to put a little of play on the gear teeth when you're setting up the mesh.
well, the hpi gear never really wore out completely, i just had to drill the set screw out of it, ruining it. there was some wear though
the robinson racing gear was in my buggy, which has a not so great motor mount that doesn't keep the gear mesh very consistant, so that was also my fault i guess
the other hardened pinion i had wore within 5 runs and everything was good as far as gear mesh goes and it just wore out as if it wasn't hardened well.
the rc-m pinion was wearing out pretty fast until one of the teeth broke off. mike wants me to send it in to get the replacement gear. he's at rcx, so that will take a while
l
like i said in my last post, hopefully the dynamite gear works good. my LHS's supplier finally has castle creations pinions in stock, so that will be my next choice.
one more thing, i had a associated plastic spur on my matrix and stripped it due to bad mesh from a loose screw. i have a replacement coming in the same order as my pinion gear. maybe if the pinion starts wearing early again, i can just sand down the wide face of the gear (like i had to do for my buggy with the first one) and try to see if it fits.
why do they even use steel spur gears in the first place? it's not like they're saving weight by doing it. i know a lot of the electrics now have plastic spurs, but almost every single nitro buggy and truggy has a steel spur. why?
