Council report to avoid overheating
galaxy76
Council report to avoid overheating - 03.22.2010, 04:23 AM
I have a E-Maxx + MM with the motor 2200kv castle creation. would like to play without worry of overheating on both asphalt and dirt with a good speed. i use 5 lipo cells. currently 68T and 21T pinion. What do you recommend
besides. But what is this?
fastbaja5b
fastbaja5b's Avatar
03.22.2010, 06:59 AM
MM on that motor will overheat, are you sure you are using the Mamba Max and not the Monster?
Say Less, Do More.
galaxy76
03.22.2010, 07:50 AM
mamba monster
03.22.2010, 07:54 AM
Just be sure to check your diffs for proper shimming. On 5s, you will tear them apart quickly if not shimmed correctly. Other than the diffs, just watch temps
bruce750i
bruce750i's Avatar
03.22.2010, 12:00 PM
Opti-drive sensor door for nitro tranny?
03.22.2010, 03:09 PM
^ That, If you remove it you can see the little pins on the output gears that the sensor would count- traxxas are just cheap and recycle parts & molds etc.
And FYI ( @ the OP ):
MM = mambamax
MMPro = mambamaxpro
MMM = mambamonster(max)- the 'max' part was dropped officialy, but lives on unofficialy in order not to confuse people between the MM and MMM.
