Freezebyte
03.23.2010, 09:49 PM
Only issues I had with my Flux stripping hexes was with Axial rims, the key is to make sure the nuts are on nice and secure so the wheel doesn't slip
JThiessen
JThiessen's Avatar
03.23.2010, 11:12 PM
I'd say you have an anomally here. It would almost be understandable if it were a rear one.
I haven't had a bad hex on any of my RC's since I converted everything to 17mm - and I'm a horrible driver. I changed mine on the Flux to the 1/2" offset optional hex setup right after I got it. Maybe try putting new hex's on - you may have gotten a bad one, or switch the tires right to left - see if the problem follows the rim.
Do you do a lot of driving on pavement?
03.24.2010, 01:26 AM
Loose nut. The nyloc (plastic stay tight thingy) on locknuts wear out. I'd try a new nut and a little locktight.
Savage-Flux
Savage-Flux's Avatar
03.24.2010, 04:52 PM
mostly, and a LOT on grass
