Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
jzemaxx
04.06.2010, 10:22 PM
Is that geared for the same speed or more/less?
I think part of the issue here will be that you can get the same runtime with a lower kv motor + higher voltage and lower mah lipo, but to see an increase in runtime you need to keep the same mah capacity & lower the current draw ( HV and lower kv again ). Having a lower mah will reduce weight but lessen the advantage you get from lower current draw = same overall runtime.
I figured the total capacity of the batts would be the determining factor. The 4S 5000mah only has 74amp/hours. The 6S 4400mah is 97 amp hours. I figured that is a larger "gas tank" per say. So it should give me more runtime. The speed is the same.
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
