Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
04.09.2010, 01:01 PM
I received the XXL chassis a couple days ago and had a chance to look at it closely. I really like this chassis, the way it's done, the way it looks and how stiff and strong it is. I'm not sure I want to change it as much as I wanted to before. So here's another idea to convert with a low CG. This idea would be very easy to do, just a new middle skid plate in 3mm CF, a new upper main chassis plate in 3 mm CF and a couple straight blocks for the new middle skid plate. Then there would be the battery covers I would make with 2 mm Kydex.
The lipos would be on their sides instead of flat. I chose to limit the size of lipos on their height to 35 mm so that the truck doesn't become too wide. There's still room to go a little wider though.
I put the E-Revo tranny in the center of the truck so it would use the same length middle shafts front and rear. I also put the motor up front with the ESC and receiver box.
The whole thing would be 200 mm wide and it would fit inside the XXL body.
The middle skid
The upper main chassis plate
a view from the top
a view from the side
a front view of the battery space
No brain, no headaches.
