rchippie
rchippie's Avatar
04.13.2010, 01:35 AM
Yeah, but you could wear some red trunks and aviators and do it Hasselhoff style.
Don't hassle the Hoff.
Boat looks good Mike. I like that gangsta mount you have, looks very blingy. Adjustment is key for a tunnel. That mount should serve you well.
I had a regular fiberglass tunnel from aquacraft, never did get it in the water. I will have to take a pic of my new "back yard". I think you will like it!
Thank's . The mount is called a hi-jack mount . It has four screws that hold to mount in place . when you loosen them then you can turn the screw in the middle . The mount will move up & down like a jack . It also has two sets of mounting holes ( high or low) . So you can offset the mount to either direction . Depending on what hull you have . It sure could use a nice paint job .
REAL MEN RUN BRUSHLESS
