Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
04.28.2010, 06:12 PM
Small project within a project here; how to make 12 to 14mm hex adaptors ( for when you cant simply install larger hex drives ):
Start off with a standard 14mm hex ( these being HPi savage items from ebay for dirt cheap- I have 17mm ones on the Gmaxx & they fit perfectly ), drill out the center with a 10mm drill bit. Then, using the edge of an eliptical file, file into the corners, leaving a couple mm before you reach the edge.
Now take a small flat file and and work away at the area inbetween each notch, keeping parallel as possible to the outside edge on each side.
You will end up with this. Note: do not overtight your vice jaws as you will crush the hex ( since it has no insides to resist the forces placed on it ).
Now turn the hex on its side in the jaws so that you can apply a bit more clamping pressure, and work away at each inside edge again with a small flat file, filing upwards as it were.
Dont be tempted to take away too much material at once, and keep rotating the hex to work each inside edge evenly, checking the fit on the 12mm hex every so often. You will end up with a very thin walled ( 1mm ) hexagon, that should be a press fit over the 12mm hex; may need to tap it on gently, but it shouldnt need hammering on- remove more material it it feels too tight, and be sure to work from the front and rear to keep the inside edges level front to rear ( dont want a smaller opening on the front vs the rear for example ).
The finished hex adapter after about 20 minutes work. This isnt exactly precision engineering, but there is very little wheel wobble once installed, just need to take your time & work each inside edge evenly to prevent the hex fitting off-center.
