Jahay
05.06.2010, 08:28 AM
30mins on 4000mah!!! So hopefully i will experience a little more run time with my 6s 6500mah batts... will keep you updated as my motor is pushing around a 14lbs pig of a truck haha
Nice pics!!! trugyy looks good... i know what i want to be building eventually....
Also what did you use on teh rear a arms to protect the shafts etc..????
itbvolks
05.06.2010, 08:39 AM
30min with 4000mah.....
Maybe messing around the yard but there's zero chance that'll happen at the track under full chat under "race" conditions. If i had to guess, you'll see 15maybe 20 min max depending on track conditions/setup.
Looks pretty good though. Certainly a big motor.
nuz69
nuz69's Avatar
05.06.2010, 08:55 AM
4S 5000mAh setup gives 12-15min in a truggy geared for 40mph, 6S 3300mAh gives a little more for the same speed (better efficiency), so i expect to have at least 20 min runtimes under race conditions. 30 min is the runtimes of bashing, 45min-1H if I walk with the truggy in the park
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
nuz69
nuz69's Avatar
05.06.2010, 05:05 PM
Test in track condition done !
19-20min on hard pushing (ratio 15/46) , motor temp after 1 run : 100F (ambient temp was 57F).
This motor has a fantastic amount of torque, it can reach its max RPM instantaneously and with 70% punch control its just soooo smooth :D
I even don't want to gear up, the ratio is just perfect for bashing or racing, and gives me the efficiency I wanted since the beginning of this project :D
Guys told me that my chassis was in fact a "prospec" MBX5T I suppose its bette then a normal MBX5T ???
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
05.06.2010, 07:50 PM
Those are some good times for that big beast... you should post your findings in Talk 1520... good info to have there.
nuz69
nuz69's Avatar
05.07.2010, 02:02 PM
New video and some photos ;)
http://www.youtube.com/watch?v=dF3EU-2BarI
