Removing solder flux from components
simplechamp
simplechamp's Avatar
Removing solder flux from components - 05.14.2010, 10:30 PM
Does anyone know any cheap and readily available solvent that can be used to remove solder flux? I just put some new Dean's on a few of my lipos and got a little overzealous with the flux on some of them. Now the plugs are gummed up and it will cause a poor connection.
So far I have tried 90% rubbing alcohol and it didn't do much of anything. I looked online and there are products made just for this purpose, but they are expensive. Also I don't want to order it and wait. I might look at RadioShack, but it will still probably be very expensive if they even have it.
Anyone have any experience here? (BrianG )
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
05.14.2010, 10:48 PM
Heat gun? It should get hot enough to liquify the flux but wont melt the solder. Then use a Q-tip or something to wipe it out.
simplechamp
05.14.2010, 11:48 PM
Hmm, that probably would do the trick but I don't have a heat gun. I might try a lighter but I'm concerned I would scorch the plastic. I'd prefer using a solvent, so I might end up getting the commercially available stuff made for removing flux, unless someone else chimes in with another solvent option.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
05.15.2010, 10:42 AM
brake cleaner or parts cleaner may do the trick
Finnster
KillaHurtz
Finnster's Avatar
05.15.2010, 10:52 AM
Maybe use the soldering tip to warm it up, then wipe as W-N? suggested
J57ltr
05.15.2010, 02:14 PM
Motor spray.
We used to use a type of freon when I worked at Western Atlas but don't remember what type. I just use a solder with water soluble flux now and use hot water and a tooth brush.
Jeff
simplechamp
05.16.2010, 06:41 AM
I ended up using Goo Gone and tried the rubbing alcohol again and between the two it cleaned them up nicely. Got 8 freshly charged packs ready to go for this afternoon! Going to go hunting for a new bash spot.
