05.14.2010, 11:22 AM
Well of course Hyperions are half the price of Maxamps these are 45C but Maxamps are 60C
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
05.14.2010, 11:47 AM
Originally Posted by mistercrash
This name just pops up in a lot of threads for no reason like a bad weed you can't get rid of.
Thats cause they are so easily made fun of with their ridiculous pricing and marketing scheme. As seen below...
I forgot about them being 60C lipos... Maybe Hyperion should advertise at 90C rates That should boost sales. O wait, they already sell good since they are priced right for the quality delivered! Shocking!
Z-Pinch racer
05.15.2010, 11:47 AM
Oh goody goody. I'm thinking I am gonna get 2 3s 4200mah packs for the season. I am wondering if it's better to get a 6s pack and split it so you have a perfectly matched pack?
05.15.2010, 01:30 PM
Interesting thought. Depends how the cells are connected together, might be hard to seperate them if they are joined via their tabs or glued together well.
Z-Pinch racer
05.17.2010, 11:04 AM
That's true, if it's anything like their last gen Enerland packs, it will be a handful. They use some kind of cold solder high pressure crimping technique that looks pretty tricky to get apart, if not impossible. I have 3 6s 4300 enerland based packs to split to 3s packs.
05.18.2010, 06:42 PM
Bon chance, I suppose...
Z-Pinch racer
05.18.2010, 08:20 PM
Once my battery supplies arrive I will start dissecting them. (balance leads, shrink, etc)
BTW, If anyone has bought a 45C pack yet, LET US KNOW HOW THEY PERFORM!
05.18.2010, 09:57 PM
i just ordered several ....HYPERION G3 VX 3300 MAH 5S 18.5V 35C/65C LIPOLY PACK...i will run 5s2p on my BL monster trucks and they will also be perfect for my new Maxxler prototype!!...Cant wait to get them in the mail
i also ordered 2 hump packs and 2 batts for my EX-10 radio....GOOD TIMES!
05.18.2010, 10:38 PM
The 35C packs are amazing! I can only imagine the 45C...
Z-Pinch racer
05.19.2010, 12:19 AM
I meant the 45C packs plettenbergs.   Why wouldn't you get the EX 45C packs I am wondering? Only ~10% higher cost over 35C.
I ran a single 6s 4200 35C pack all racing/bashing season last year, still performs 100%.
05.19.2010, 04:21 AM
Someone said the Hyperion is only making packs in the 5000 mah range.They said it`s due to restriction of shipping packs over that size.
It was in a post on the Traxxas board
05.19.2010, 07:40 AM
I have 45C 5S 4200mah hyperion pack on the way. Will let you know how it compares against 35C pack (though only 3300mah)
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
Z-Pinch racer
05.19.2010, 11:08 AM
No way! Tell me how that makes any sense? Seriously, we all know a 6s 3000mah is just a hazardous as a 3s 6000mah... is that what they are saying? This is beyond retarded if I understand what's going on. I am lucky I run a 6s setup, only need max 4000mah, otherwise I would be running 6000+ with a 4s pack. So what brands does this apply to? Where are these rules coming from?
Wallot, good to hear, and do let us know. Do a cell check before you use it, and do a couple soft cycles on your charger before you use them, and then go easy on them for the first 10 cycles at least in your R/C. Should get some serious power out of them after that.
05.19.2010, 12:02 PM
There are restrictions on the amount of lithium that can be in a battery - This s approximated into Whr on a pack so a function of capacity and voltage - hence 6s 3k and 3s 6k would be the same w/hr...
Z-Pinch racer
05.19.2010, 12:06 PM
Yeah, still how does that make any sense if they limit Ah? They sell a 12s 4500mah pack, does that make it less hazardous? Is there both an Ah and Wh limit?
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
