Thread Tools Rating: Thread Rating: 16 votes, 4.75 average. Display Modes
95ROLR
05.19.2010, 07:37 PM
Originally Posted by hootie7159 View Post
they'll fit..but you still have to grind down the inner lip of the revo adapters..
What this guy said.
Revo hexes fit well but grind down the lip. Also, don't just grind down and throw on... Try and keep test fitting. Grinding off too much will cause there to be slop (found this out the hard way... Fortunately I had a spare kicking around from something).
As for the wheels/tires... The truck rips like it's on rails which is nice in a way but unfortunately requires a bit of a learning curve considering i've never had anything that drove like this. If you bash with your Ten-T, Badlands are nice, if you stick to track, get something else.
I also put strips of velcro on the top/side/outside of the chassis and bottom of the body and leave the body clips at home. You can see in the pic through the tuned pipe cutout where the blue velcro goes across. The velcro holds the body very nice... down with body clips!
