reno911
Smelly Nitro meet your maker!
reno911's Avatar
05.24.2010, 02:34 PM
It has been programmed but yes you will need to calibrate it to your radio.
If I remember right if you follow these steps you should be okay.
Set all of your radios trim to 0.
Turn on your radio and leave it on.
Plug in a battery to the ESC and while holding down the little red button on the side of the ESC turn on the ESC.
Hold this button until light starts blinking.
With radio in neutral hit the button once, motor should beep and light should blink.
With radio in full throttle hit the button again, same thing should happen.
Lastly place the radio at full reverse hit the button again. Same as last two should happen.
The ESC should be calibrated to the Radio at this point.
I'll find the PDF online when I get a second as well to help with this.
Sorry about this! Wish I had the instructions with the esc to give you with the Mini!
