Vic
06.06.2010, 05:37 AM
Originally Posted by nuz69 View Post
We have all the same problem. Remove it and replace it. It is weak against dust.
...and lose my warranty? But I already opened the case...so it is gone anyway isn`t it?
nuz69
nuz69's Avatar
06.06.2010, 05:46 AM
No, you can open the case to change the fan, and you can remove the switch without lose your warranty, don't worry.
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
Vic
06.06.2010, 07:21 AM
With "remove" you mean to heat up the point where the red and black cabel come together with the solderiron to melt the solder. should I replace it with an new switch or should I just leave it without it?
Do I nead an special solder iron and solder?
Thanks
nuz69
nuz69's Avatar
06.06.2010, 07:36 AM
You just need to cut the two wires, and to solder them on another switch, you don't even to solder them, just attach them together, it should the the trick.
