Metallover
RC-Monster Spudgunner
Metallover's Avatar
06.06.2010, 01:16 PM
That whole pile of parts looks sexy! You'll get some serious power from those cells!
That motor might look sexier with cooling holes and a fan tho,,, If you ever need them
Make sure you run a couple torque arms in the back.. I didn't see any in the picture. I did see what I think is a disc brake adapter tho! Very nice!
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.06.2010, 03:46 PM
Yeah man, the 720i HP is reporting them to be 1mOhm (probably the lowest it can go?) each. Cell_man did some discharge tests on endless sphere, can discharge 600amps @ 2.0v/cell IIRC. I am going to buy a 1200watt charger for it to get less than an hour 0-100% charge. If you calc the power density from the 26650 M1's, it should have a solid 17kW power capability, so obviously it's not going to break a sweat at ~2000watts peak.
Those holes look scary to me.
Oh, and do I need a torque arm for the rear?
