06.09.2010, 01:00 AM
Originally Posted by blueb8llz View Post
are all fuel tubing the same diameter? are does anybody know the right size of fuel tubing i will need for lst shocks?
i still would rather much use something plastic than the fuel tubing. what you guys think of using pistons. but the holes in the pistons may affect something maybe....
I understand why you are leary of fuel tubing, but it has been used many times and is a tried and true method of limiting shock travel. Any fuel tubing labeled for nitro use will work. Your making it more work and cost than it needs to be
