nuz69
nuz69's Avatar
06.30.2010, 04:45 PM
As the spur use itself with time, I thought that I had to move the pinion closer to the spur, but with this method I used my pinions pretty quickly... So now I decide to stick with the original shimming when the spur was new, and it seems to work, my pinions and spur dont use themselves anymore. At least for the moment...
I run with the mesh you see in the photo
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
06.30.2010, 04:52 PM
hmmm.... just curious... how did you determine the distance between the spur and pinion?
nuz69
nuz69's Avatar
06.30.2010, 04:58 PM
I have some plastic piece between motor and chassis reinforcement, which keep the motor to move latteraly, and it give me information on the shimming too.
And I can feel it with the play between pinion and spur when I move the spur up and down.
ANGRY-ALIEN
06.30.2010, 05:14 PM
zeen... I get a little confused myself when meshing metal gears... with plastic spurs and metal pinions i used the 'Paper Method'... running a sheet of paper
between the gears to achieve a relatively good mesh... But I'm sure if that method can be used with metal gears...
nuz69
nuz69's Avatar
06.30.2010, 05:17 PM
Some people do that with metal ;)
But I prefer the hearing method, I hear carefully the noise that my mesh is doing to adjust precisely the shimming. I use my eyes too, with habit you can see a proper or bad mesh, and the noise confirm it !
