Slash 4x4 RPM Bumper on my TEN -
07.01.2010, 09:46 AM
I used the Slash 4x4 bumper because the two front screws matched perfect,I removed the stock bumper and added longer screws. Still might drill and tap two more screws to make it bulletproof.....
Next is the Proline Protrack wheels they are neg.10* and put you at the legal with.
Teckno has the wheel hexes 12 mm no mod needed: http://www.impaktrc.com/product_info...cb7f0744b5ad5c
Glenn Carlson
XXX-CR
XX-4 WED
8IGHT E
TEN SCT
Losi everything!!
I got the tekno hexes, yes they are drilled for 6mm axles. The Problem I found is the pins, they use the stock traxxas pins which are much smaller than the pin holes in the axles so there is alot of play. Going to try to dremel the hexes to use the tent pins.
By the way I HATE this POS iPhone, took 8 minutes to type this. POS does what it wants not what I want it to do, pretentious proprietary aholes.
