Ryu James
Ryu James's Avatar
07.10.2010, 11:06 PM
Originally Posted by stum View Post
Does anyone else have issues w/ missing laps /w the transponder when upside down under the radio tray? My last tekno 8b 1.0 kit had this problem and I ran into again racing w/ the tekno 2.0 kit and both had shaved down trays. I moved my transponder to the inside edge of the mud guard right next to the radio tray and it works great..
just figured id ask
PS MANY people would buy updated mud guards.. so it wouldn't be just new units getting the benifit.. I as well as most would be happy to snag a set if they were a good design that did a better job protecting.
if you read the instructions in your transponder it says that the unit MUST be mounted flat with the bottom side facing the ground to work properly. my guess is if you flip the unit over and mount it as the instuctions say you should be fine.
i have had transpnders that miss laps before and couldnt figure out why. usually i just try mounting it in different spots until it works 100% of the time.
Jammin SCRT10 Neu 1512 1y
