stampy
stampy's Avatar
07.15.2010, 11:20 PM
why use a soldering iron. i use a propain torch. heat up the bullet connector feed in the solder so it fills about 2/3rds of the connector and just stick the wire in there continuing to hold the flame on the connector until the wire sucks up the solder and your done :) ive found its the easiest way for me.
georgec
georgec's Avatar
07.16.2010, 11:45 AM
I like this idea! I have a small jewelers torch that should work quite well.
JThiessen
JThiessen's Avatar
07.16.2010, 01:06 PM
With a soldering station, I can get the cup hot and filled in about 15 seconds or less. No need for a torch (although there is something manly about an open flame!!!)
