Thomas Porfert
Thomas Porfert's Avatar
07.20.2010, 10:34 AM
@Nuz 69: You're running a 4-pole motor, so you will need to divide the result by 2.
If I understand the setting correctly, because it's limiting the torque of the motor, it will supersede the effects of punch control; which is more of a voltage/RPM limiter. (correct me if I'm wrong Pat)
I'll let the engineers know about the issues with the torque control start-up.
The fan should not be running the entire time, torque control should actually reduce motor and ESC temps. Not sure why, but that is what I was told be Richard (our software engineer). Hopefully Pat can shed some light on the how and why.
I'll check with Richard and find out why the fan is running continuously. Was it a Mamba Monster or Mamba Max Pro??
@Fg101C: Did the problem persist when you turned off torque control? Or did you have the issue with it turned off as well?
Thomas Porfert
Castle Tech Support
nuz69
nuz69's Avatar
07.20.2010, 10:51 AM
Thx for your feedbacks P. and T.
==> My ESC is a Mamba Monster.
==> The torque control is in fact a current limiter, as the torque depend of the current ?
==> the cogging/crawling problem occured only with the torque control activated, so it's not due to the new firmware.
==> When I said that activate the torque control cancels the effect of the punch control, it's really the case IMO. For example, like you said Patrick, when you hit full throttle quickly without punch control, the motor will reach instantly its max RPM. With punch control you will see a delay until the motor reach the max RPM. When I activated the torque control (I set the value to 3.0), I did some throttle test, and the motor went instantly to max RPM, when I deactivated the torque control it was'nt the case anymore. That's why i said that.
Give me the time to run some other tests without punch control and I will post more feedbacks.
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
Pdelcast
Pdelcast's Avatar
07.20.2010, 10:57 AM
Give me the time to run some other tests I will do more feedbacks
Cool, thanx!
The torque control will give instant response to throttle changes (unlike punch control...)
So if you hold the model, you will see the wheel RPM change almost instantly. There is very little torque required to change the wheel RPM.
But on a track, the torque control will make the car/truck act as though it has a lower torque motor -- wheelspin will be more controlled.
Traction will be greatly increased, with no impact to throttle response.
We've got a little more work to do to finish the full traction control implementation, but this is a good step forward towards full traction control.
Thanx!
Patrick
Patrick del Castillo
President, Principle Engineer
nuz69
nuz69's Avatar
07.20.2010, 11:02 AM
Escuse my french language, but "wheelspin" design the fact that the wheels spin with no grip ? Like while a drift ?
Pdelcast
Pdelcast's Avatar
07.20.2010, 11:05 AM
yes -- that's what I mean by wheelspin. For example, when pulling full throttle from stop, the wheels will spin much faster and harder without torque control. Acceleration will be more controlled and faster (with less wheel spin) with torque control adjusted correctly.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
