Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
brian015
brian015's Avatar
07.21.2010, 07:19 PM
Are you going to be investing in the new castle ESC when its comes available???
I'm happy with the mechanical brakes on this, so I don't think I'll need the HV truck esc.
i know what you mean about destroying bearings in the axles... One of mine fell apart the other day and i couldnt get the outer rim of the bearing out of the carrier! Was so annoying... how would you add another bearing without shortening the drive shaft and extending the axle? Really interested if you can come up with a fix... I was going to do a big boca bearing upgrade, but considering the stress put on the axles i would prefer to change the axle/hub bearings with cheap ones as they wont last long....
I'm planning on putting an extra bearing inside each LST2 carrier where there is now empty space - in between the two current bearings. For the front spindles it looks like only very minor shimming to get a snug fit. For the rear carriers I'm waiting on some thin-walled aluminum tubing to use between the bearing and carrier for a solid fit.
