Reno911 - since I'm using two servos, what should I set the voltage to if each receives 6V? Is it a simply 6+6 = 12V? Please keep in mind I'll be connecting the two via a y-harness.
Thanks.
You don't need to supply twice the voltage, but it will pull more amperage. Which the BEC should be capable of.
