Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
07.27.2010, 12:51 PM
i don,t know if it is normal, but on my LST2 diffs, if i hold the diff in one hand, and with the other hand i take the pinion and try to move it up/down and left/right, i can see the outer bearing move slightly in the diff case.
Yeah I noticed this as well. My drive cup (pinion) moves up down and sideways about 1-2mm inside my diff case. I thought I had a bad bearing, I havent torn into it or looked very closely. Its the case? Anyone else notice this? is there a easy fix? This is just asking for my ring gear to strip out.
CRASH - Maybe you could try the 8ight bevel gears. I think they seem to be made of a better metal. Just looked more clean and beefier when I compared the LST spiders next to the 8ight spiders while building a CD... Might be worth a shot.
LST- http://www.amainhobbies.com/product_...l-Gear-Set-LST
8ight - http://www.amainhobbies.com/product_...Gear-Shaft-Set
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
