I think the temp of the slipper wouldn't matter as long as your motor's & ESC's fine. Just make sure u do regular maintenance of the slipper and change difffluid if needed. The slipper spur rubs directly on the pinion which both are actually steel rubbing against steel so high temps are normal. :)
Just my opinion.
