JoFreak
JoFreak's Avatar
08.20.2010, 08:41 AM
@SpEEdyBL: I use a Hitec HS-5645MG and because I thought of a BEC issue I tried to use a receiver battery.
@Arct1k & brushlessboy16: Now what do you suggest I should have done?
"Uh, I think the ESC might not be in perfect working order, better put it on the shelf and never use it, because it might blow" ?
brushlessboy16
brushlessboy16's Avatar
08.20.2010, 08:54 AM
Send in the esc when you noticed something wrong... that would make the most sense no?
Since you knew that something was wrong and continued to run it who knows if they will even warranty it.
