08.23.2010, 09:55 AM
Originally Posted by OZ-RUSTLER View Post
...If some of you can help me with working out how my lipo's went, it would be much appreciated. I had the LVC at 3.4v and when it hit, I just disconnected the lipo's and took a reading of voltages and all cells were around the 3.7v mark...
I assume you want to know why the LVC was set at 3.4v/cell, yet the cells were 3.7v when measured? Two reasons: 1) cell voltages will drift back up a bit when left unloaded for a few minutes, and 2) depending on how the LVC actually works, if it read a momentary 3.4v/cell voltage sag because of high acceleration urrent, it would trip the LVC even though the nominal voltage is closer to 3.7v/cell.
Nice job by the way!
brian015
brian015's Avatar
08.23.2010, 11:44 AM
2) depending on how the LVC actually works, if it read a momentary 3.4v/cell voltage sag because of high acceleration current, it would trip the LVC even though the nominal voltage is closer to 3.7v/cell.
That's what I see with the HV ICE 160. The power will cut off under hard acceleration near the end of the pack (voltage momentarily drops below lvc setting), but will continue to supply power if I drive less aggressively. A good feature - meaning I can drive it back to my car at the end of a run, rather than carry it. Probably also good for airplanes to allow them to land - which it was designed for.
