MetalMan
MetalMan's Avatar
02.26.2006, 02:20 PM
Originally Posted by maxxdude1234
Thats a pretty good deal TBH, and its much cheaper than the 2s2p 8000mah packs. It's not voltage that damages controllers, its current. You stand a bigger risk damaging your controller with 4s lipo and a hotter motor, than you do with 6s and a high turn motor.
With 6Ah of charge in those packs you will have absolutely know problem doing a couple of warm up laps, followed by a 20minute main, followed by a couple of victory laps (after you smoke those nitros) :D:D:D
Current, eh? High voltage could actually be more likely to kill a controller than high amps, since these controllers usually have thermal shutdowns caused by the heat produced when a lot of current is drawn. High voltage can actually damage the components, and that is a huge reason why there are capacitors on the input of controllers like the Warriors and MGMs.
maxxdude1234
maxxdude1234's Avatar
02.26.2006, 02:31 PM
I stand corrected....
Still you wouldn't want your controller to thermal in the middle of a 20minute main.
