Bmr4life
09.17.2010, 08:19 PM
Are these the spring people are talking about when they say White Hellfire springs? Link
I like that shock tower bracing, real neat.
Are the stock shock towers supposed to be slanted at all or straight up and down? Mine are slanted but they were like that when I got the truck.
_dV
09.17.2010, 08:28 PM
Yes those are the springs.
The shock towers will permanently deform over time. Left deformed, right new.
The diff casing angle on the front means the tower would lean in toward the center of the truck a bit but the rear should be close to straight up and down if it isn't bent.
thzero
09.17.2010, 10:52 PM
Yes. The front shock tower slants back due to the kick up at the front for caster. The rear shock tower does slightly lean forward.
Those are the springs. The Flux shocks (and the BB versions) use the Hellfire springs. I'm running white on my 17lb 5T, however I am thinking about going to the yellows.
Here's a list of all the springs:
#86549 SHOCK SPRING 18x80x1.5mm 12.5 COILS (BLUE 71gF/mm)
#86550 SHOCK SPRING 18x80x1.5mm 10.5 COILS (SILV 89gF/mm)
#86551 SHOCK SPRING 18x80x1.8mm 14.5 COILS (PINK 134gF/mm) (Flux kit part)
#86553 SHOCK SPRING 18x80x1.8mm 12.5 COILS (WHIT 159gF/mm)
#86554 SHOCK SPRING 18x80x1.8mm 11.5 COILS (YEL 177gF/mm)
#86555 SHOCK SPRING 18x80x1.8mm 10.5 COILS (RED 196gF/mm)
Bmr4life
09.17.2010, 11:50 PM
Thanks a bunch for this spring info. I'll give the stock shocks another chance with some white shocks and 45w oil.
