bigboi146
Multi Tasking
bigboi146's Avatar
09.19.2010, 09:35 AM
On 5s I had mine geared from 14-16 with the 52 tooth pinion... Never had heat problems.
09.19.2010, 02:20 PM
For temp readings, try aiming the gun at the base of the motor wire bullet connectors, and in the side of the esc case between the slots- kinda tricky to get a good reading but you can get a general idea if the whole thing is hot or just warm..
