pinkpanda3310
pinkpanda3310's Avatar
09.22.2010, 11:16 AM
Bear in mind the 45-90c rating of nano will mean little if you are not satisfied with the solder. Plus you run 9s yeh? Do you have a logger? If you do then you would know if you are using the limit of your current (now) batteries and or what the system draws. Then (as stated) get a battery that has lots of head room.
