mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
10.22.2010, 10:06 AM
I find the two manufactures tranny's to be relatively the same. Out of the box, not reliable for 6S.
I can't comment on the Flux tranny, some are very happy with it with upgraded gears in it. I know for a fact that the gears in the Traxxas BL E-Revo tranny don't need to be upgraded. I ran the E-Revo tranny on 6S in a 14 pound LST XXL all summer remember? The E-Revo tranny is very reliable on 6S. I will admit that it does need one inexpensive upgrade though, the Hot Racing double slipper. If you happen to have the newer model of tranny that comes with the aluminum slipper pads then you're all set, absolutely no upgrade needed for 6S.
No brain, no headaches.
JThiessen
JThiessen's Avatar
10.22.2010, 11:06 AM
That's true. I wonder though what the outcome would have been if you hadn't blown your diffs all the time (may have been the same outcome....nobody knows for certain).
mistercrash
Guelph, Canada, eh!
10.22.2010, 01:03 PM
Well the fact that the rear diff blew so often shows me that it might have been the weak link in the drive train. And that LST XXL diff with the HD cup is well known to be very strong and dependable. The E-Revo tranny always came out shinning with no visible signs of wear. We will surely find out how the outcome will be and if that tranny will still perform as well because the truck is on its way to nitrostarter as we speak. Maybe he will find if there was a problem that I over looked about the rear diff.
josh9mille
josh9mille's Avatar
10.22.2010, 01:20 PM
I have to agree, the revo tranny is amazing, especially for being plastic. Probably has something to do with the 1/2 inch wide contact pattern on all the gears.
mistercrash
Guelph, Canada, eh!
10.22.2010, 01:28 PM
My opinion also, and there are three gears in there, two are metal and the big one on the output shaft is plastic.
josh9mille
josh9mille's Avatar
10.22.2010, 01:56 PM
I didnt know that, i thought they were all plastic. I never had to tear mine appart so i wasnt sure. the tranny is the only thing i never had a problem with.
