_dV
10.25.2010, 08:46 AM
Few more quick comments:-
Body Clip Pulls
The antenna tube body clips pulls I made worked well. Easy to make, cheap, very durable, don't get caught and pull out the pin and easy to use despite looking small and thin. Recommended
Battery Tray\Holder
Tray was fine, solid. Tekno battery holder though is not up to containing a 6S battery. There is a small depression in the bottom of my 6S battery from the tray side pressing on it in hard impacts. Need something with higher sides like an RC Monster custom tray or just devise something different.
Shock Covers
Do an ok job and they wash out well. Very susceptible to stone strike on the rear but decent rear stone\mud guards help out with that. Think I will try some RC-Skins next.
Slipperential
Nice piece of engineering but not quite suited to applications in an MT, at least from my experience. Really needs stronger wave springs that apply the pressure more evenly. With 3 I have to almost tighten them right up. There now also isn't a mod1 steel 52t spur available. I will say that besides some initial quality control issues it has held up well to the abuse.
Looking to cut the slipper and try a Vorza center diff with lightweight 52t hellfire spur and 500K or Ofna diff lock fluid next. Other options are:-
- some kinda Torsen CD (usually expensive and haven't seen reports of use in MTs)
- a CD with a locker.locker 2. locker 3
- Ofna spider diff (more expensive and difficult to find but stronger with more gears that will increase the effect of the heavy diff fluid)
- Dual pad center slipper from the Bullet Flux. No idea atm if this would work. Gear is a bit too large for my application for starters. Drive cup size?
- Kershaw Designs direct drive. Not keen on the design for various reasons and the motor placement doesnt work with my build.
- Home brew direct drive. Unlikely I will attempt this.
