Manne
10.25.2010, 02:02 PM
"they arent any stronger than the xxl diffs, they are just a diffrent ratio"
I strongly dissagree,
look at this picture:
And this:
A stock 1/8scale savage diffs Vs BP.... No difference? Looks bretty much more beefy in my eyes
Currently Iīm using stock diffs, with alu cups, shimmed properly, no play and no binding.
My problem isnīt that the pinion is "jumping over" a few tooths on the ring gear. The problem is that the tooths are losening from the ringgear..
I have my slipper adjusted correctly, loooose, and I never land with throttle..
Back to the topic, does anyone know if there is a chance that the bp diffs would fit in the losi cases or revo hybrid cases?
I looked at the exploded views of the losi diffs but there was no information on what bearing size the lst diffs pinion and ringgear/cup uses..
If anyone knows the size I could compare it to the savage bearing sizes and see if there was a chance to make this work
10.25.2010, 04:10 PM
Manne- you showed a side by side comparison of the SAVAGE XL diff and a BP diff, of which yes, the new bp version is stronger.
semipro was referring to a LOSI XXL diff, so your picture has nothing to do with what he said.
I believe his point was that Losi diffs in Losi cases are more than strong enough for a light revo. Whatever diffs fit in the revo hybrid cases are also more than strong enough in a light revo.
So it's much easier to just use one of those methods rather than "reinvent the wheel" so to speak.
I think you got caught up in hpi's marketing. Yes they are called bulletproof diffs but they aren't "the best of the best"
I can't answer whether or not the diffs will fit, I can say it's much simpler and JUST AS EFFECTIVE to use lst diffs or hybrid diffs.
Basically there is no point in doing what you're doing. It's like putting a spoiler on a station wagon.
But if you really wanna do it go for it! Post pics!
Semi Pro
Semi Pro's Avatar
10.25.2010, 07:13 PM
thanks paralyzed you said it much better than i did
as for monster being the home of overkill i agree, but hey its his money......op buy them and make them fit, its that easy
