ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
10.29.2010, 02:54 PM
Originally Posted by Thomas Porfert View Post
Not really intended for 3s on the 2wd slash. ESC temps will get a little high along with motor temps. You would be very limited on gearing and may have to keep the run times under 5 minutes. Thomas Porfert
Castle Tech Support
I Realize you work for CC but I still think the motor will handle the 3s in a rustler or 2wd slash just fine. Considering the weak 2 pole VXL motor pushes my Full Aluminum Rustler with masher 2k's. Maybe the Speedo will run a bit warm but I dont see the motor needing cool down every 5 minutes
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
ChrisAttebery
10.29.2010, 06:36 PM
I have this system on the way. Since this motor has so much torque I'm wondering if it is going to present a problem for those of us running 2wd.
Does this ESC have a torque control setting?
If not, can torque control be added to to the firmware?
If torque control was available, could you set it up so that when Torque Control is enabled via Castle Link Software:
A) "Punch Control" is disabled
AND
B) Field Link could use the Punch Control adjustment to adjust the Torque Control?
Thanks,
Chris
ChrisAttebery
10.29.2010, 08:54 PM
OK, I downloaded the Castle Link software and it looks like Torque Control is available on the Sidewinders. It would be cool to be able to adjust it with the field link card in place of Punch control.
